Tractor Supply Powerblock
jddriver
03-07-2005 15:52:58
I have a powerblock for a John Deere 60. Can someone tell me waht it should be worth? It's in very good shape. Dad needs hearing aids and we are trying to raise funds for buying new hearing aids.
Thanks,
Steve
Mike N Mo
03-07-2005 16:03:47
 Re: Tractor Supply Powerblock in reply to jddriver, 03-07-2005 15:52:58
What condition is it in? Does it need bored? Pistons with it? The value mostly depends on these questoins. Mike
jddriver
03-07-2005 18:42:03
 Re: Tractor Supply Powerblock in reply to Mike N Mo, 03-07-2005 16:03:47
No pistons. Type of block that has sleeves, but they are not included. Otherwise in good shape.
Steve
a puller
03-08-2005 18:15:36
 Re: Tractor Supply Powerblock in reply to jddriver, 03-07-2005 18:42:03
what do you want for it? i am somewhat interested. Email me at [email protected]
2 Cylinder
03-08-2005 06:56:15
It is probably not worth much more than a regular block. It is missing the very things that give it value. I gave $450 (3 years ago) for a #2 that fit the a 47-49 JD-A, and it had everything included (pistons, rings, wrist pins and sleeves) and was out of a running tractor. It is only worth what someone will give you for it, probably $100-$200 if that. Sleeves and new piston aren't cheap unless you can machine them yourself.
