Timing
Farmall H Pulle
03-07-2005 14:05:36
Hi I have a Farmall H with an eletronic ention. I can' t get it to run right. It was running fine last week and one day i was driving it i shut it off and went to start it and it backfires through the carb and when i get it running it is real ruff. it also has carbon fiber wires. I have also timed it right. Could it be the eletronic ention?
thank you , Miles
ChadS
03-07-2005 15:03:03
 Re: Timing in reply to Farmall H Puller, 03-07-2005 14:05:36
Double check you coil wire, mite have burned the fiber out creating a short. Intake valve too tight, vacuum leak, or the coil is going bad. Some coils, can go bad when using the electronic conversion. You are now running the full power from the coil to the plugs, and can overload a possobly failing coil. ChadS
