Powerblock help
larry f
03-05-2005 07:32:36
I need a set of plowerblock sleeves or a complete powerblock. Please email me if you can help me thanks
Drew
03-05-2005 10:56:31
 Re: Powerblock help in reply to larry f, 03-05-2005 07:32:36
Which powerblock are you looking for? If you are looking for stock powerblock sleeves, I think they are pretty hard to come by. You can get your block sleeved a little bigger without going wild, but make sure the sleeves are welded in.
larry f
03-05-2005 14:25:38
 Re: Powerblock help in reply to Drew, 03-05-2005 10:56:31
The powerblock i need is for a 1950 A. How much bigger and ware can i find these?
jugs
03-05-2005 15:46:10
 Re: Powerblock help in reply to larry f, 03-05-2005 14:25:38
A guy called me last week, had a power block for a late A or 60. Wanted 500.00 for it. Had a crack on the outer part of sleeve, not a problem there. Had it repaired. If interested, let me know and I'll pass his number on to you.
a puller
03-06-2005 23:56:38
 Re: Powerblock help in reply to jugs, 03-05-2005 15:46:10
i am interested in the powerblock for 500. can you email me? thanks alot
Deere Puller
03-05-2005 21:01:49
Hey Jugs, I'm new to pulling, how can you tell a power block from original? I have a few 60's, have thought of pulling one??
JDMark
03-06-2005 04:02:00
 Re: Powerblock help in reply to Deere Puller, 03-05-2005 21:01:49
One easy way to tell a powerblock apart from a stock JD block is the powerblock has no petcocks cast into them, and when pullers put petcocks into them they are on the bottom of the block at the base of the head studs. Mark
a puller
03-05-2005 21:24:31
yes, you can tell the difference. they say power block 6-3 on them. if they don't have it on, it has been ground off..and then you can tell them if you know what to look for...spark plug angle, block contour...grind marks under paint..... all that jazz....
larry f
03-05-2005 18:11:35
If you could find the phone number that would be great. You can email me
