pulling Camshaft
STONEY
03-04-2005 21:18:54
Where can i get steel camshaft made.
brad gray
03-05-2005 12:10:31
 Re: pulling Camshaft in reply to STONEY, 03-04-2005 21:18:54
What are you looking for? I have around 50-60 billet cams on the shelf. Prices range form $300 for an IH 466 to $650 for a 585 Moline. I stock 310 Waukesha, 5.9L Cummins, 301 Allis, 426 Allis, Massey 540, Massey 640, 3 different small block deeres, Big deere, 504 case, and Ford truck/tractor cams. (you get the point) Be glad to help if I could. I also have a 2cyl G cam with gear (oil pump gear) on it ready to grind for $1000.
Good Luck,
Brad Gray
412-585-3913
Copy and Paste Website Link Below to See Pictures of Parts: Link
Carney
03-04-2005 22:27:24
I have made them. What is it for? The grinding and treating gets a little expensive like about $600 for a 6 cyl plus the billet turnout which isn't too bad about $60 for material and $200 to $250 for labor depending on what it is. Than if you need a gear cut on it for an oil pump or dist that gets pretty $$$
