Question for NATPA pullers
ronlukow
03-04-2005 20:16:21
I see a lot of tractors w/pressure tanks ("Moon tanks", once upon a time) mounted out front. Is this for fuel? Or coolant?
We don"t see those much in ITPA, I don"t think-but maybe I haven"t paid attention. Just curious
Thanks
farmall2
03-05-2005 05:37:29
 Re: Question for NATPA pullers in reply to ronlukow, 03-04-2005 20:16:21
The tanks are not 'pressure' tanks they are vented. But yes we use them for fuel.
ronlukow
03-05-2005 10:51:47
 Re: Question for NATPA pullers in reply to farmall2, 03-05-2005 05:37:29
So Farmall, would that mean that all tractors w/these tanks run fuel pumps? Always looks uphill to bowl to me.
Wondering why the alum tanks have replaced stock gas tanks?
I'm not challenging, I'm just curious about what I see in pictures.
Thanks
Steve Crum
03-06-2005 12:58:03
 Re: Question for NATPA pullers in reply to ronlukow, 03-05-2005 10:51:47
A few are infact stainless tanks equipt with a Ford in tank fuel pump designed for fuel injected engines.
Marty in Mi.
03-05-2005 12:57:41
Some tracks really are tough,and for these tracks,you need all the weight that you can get up front.Even though these little tanks full of fuel only weigh about 25 pounds,that little bit of weight can sometimes make the difference between a full pull and two feet shy.They are also inherently corrosion resistant,so one doesn't worry so much about plugged fuel filters or clogged ports in your carb.
ronlukow
03-05-2005 20:57:31
 Re: Question for NATPA pullers in reply to Marty in Mi., 03-05-2005 12:57:41
Thanks Marty
I can see the weight/arm thing OK.
But-fuel pumps would be necessary-right?
Thanks
A.P.
03-06-2005 03:48:24
 Re: Question for NATPA pullers in reply to ronlukow, 03-05-2005 20:57:31
Some type of fuel pump would be required. It might jumpt be a lift pump from the diesel version of the tractor or an electric pump of some sort. You could even set up an intank pump if you were real energetic. Unless the fule tank is higher than the carb.
