what kind of fuel?
super_m
03-03-2005 11:18:46
i am a new puller still learning.what is a good fuel to run in a stock motor with a k&n filter?
ksiv
03-04-2005 09:36:52
 Re: what kind of fuel? in reply to super_m, 03-03-2005 11:18:46
I'd run the lowest octane possible. The octane number is just a value that represents it's resistance to knocking, not it's power making ability. The higher the octane rating, the slower the "burn" rate. (and the less hp you make). only high compression engines need high octane fuel. Just my 2 cents worth.
Mike S 806/H
03-03-2005 15:33:11
I would run 87 octane the lower the octane you can run the more hp you can make, just make sure you have no spark knock
Farmall H Puller
03-03-2005 11:31:07
Hey I would run 93 octan in that M.
