880 Crankshaft Dowel pins, do I need them?
torquenut
03-03-2005 05:12:03
Putting together a small Oliver engine that will turn no more than 2500 RPM on occasion, just over 400 cubes and should make around 95 - 100 horse I suppose.
My question is do I need the dowels on the end of the crankshaft? The crank is drilled for them... I guess I could order them from AGCO if nessesary. Thanks in advance for any wisdom.
Torquenut
ksiv
03-04-2005 09:40:25
 Re: 880 Crankshaft Dowel pins, do I need them? in reply to torquenut, 03-03-2005 05:12:03
What size do you need?
I probably have them.
Kev
torquenut
03-04-2005 11:21:25
 Re: 880 Crankshaft Dowel pins, do I need them? in reply to ksiv, 03-04-2005 09:40:25
Ksiv, hi bud. I called Elders and have two on the way. For ref. they are .4375" x 1.8125".
88Power
03-03-2005 19:19:26
Torquenut,
Dowel pins on flywheels are needed for two reasons:
1) to center the flywheel to the crankshaft, i.e. without them, it's possible to get the flywheel off to cause an imbalance.
2) act as a positive lock to help carry the shear stress from the load transfer between crank and flywheel. The job of the capscrews is to maintain clamp load to the crank.
I would not run without them and have a couple extra new dowel pins if you can't find any. Running without dowel pins is a good way to turning your flywheel into a buzz saw. Also, I always use Loctite on flywheel capscrews.
torquenut
03-04-2005 05:50:57
 Re: 880 Crankshaft Dowel pins, do I need them? in reply to 88Power, 03-03-2005 19:19:26
Thanks for the insight, I called the dealer and they have two new dowels on the way.
BushogPapa
03-03-2005 06:56:03
If it is drilled for them, I would use them... They are prescision-drilled for a good fit, and will keep the flywheel from working the bolts, and loosening up...
Jerry Cent. Mi.
03-03-2005 13:30:51
 Re: 880 Crankshaft Dowel pins, do I need them? in reply to BushogPapa, 03-03-2005 06:56:03
If you have a Tool and Die shop close, they will have lots of them. They are used in stamping dies.
