dt 466 in 560 ?
like 560 tracto
02-25-2005 04:01:46
new to this i have a 560tractor that i would like to put a new DT 466 275 horsepower in.looking to do some a little pulling but mostly use as farm toy what would be involved. the tractor has a bad engine bought engine for short money. dose any body no of what parts i would need and any pics i could see of that set up also would the trans hold up. and is the stock radiator enough to run cool. thanks much
jthhhhhh
02-26-2005 14:44:33
 Re: dt 466 in 560 ? in reply to like 560 tractors, 02-25-2005 04:01:46
a 666 or 686 backing plates are to small you need a 766- 1566 backing plate but none of the flywheels will work there not long enough
Redman
02-27-2005 19:38:16
 Re: dt 466 in 560 ? in reply to jthhhhhh, 02-26-2005 14:44:33
i sure would like for you to show me how you are going to bolt a 466 to a 560 rear with a 766-1586 rear engine cover.
i believe you have never heard of a spacer plate either.
jthhhh
02-28-2005 13:49:48
 Re: dt 466 in 560 ? in reply to Redman, 02-27-2005 19:38:16
if you would email me you email address i would be happy to show a picture of a 466 in my 560 with the 766-1566 backing plate. a 666 686 backing plate fits a 460!!
ChadS
03-01-2005 06:39:00
 Re: dt 466 in 560 ? in reply to jthhhh, 02-28-2005 13:49:48
May I see the picture too? ChadS
like 560 tractors
02-28-2005 17:29:26
thank you i would like that it is [email protected]
Redman
02-25-2005 15:09:07
rear engine cover and cltch off a 666 or 686 with 312 american diesel for the rear.
the front will require adding into the frames as i recall for engine mounts,use front cover off a truck they are narrower.
rear will take it for pulling,but not for extended use in the field.
radiator should be enough if you don't plan on working the snoot out of it.
