weights
super_m
02-23-2005 15:06:05
where is the place to put suitcase weights and 1 or 2 sets of wheel weights on a super m pulling in 5,500 and 6,500 pound class.and is 7,500 to much to pull for a m?
dej(JED)
02-24-2005 06:34:51
 Re: weights in reply to super_m, 02-23-2005 15:06:05
Weigh placement is a trail and error scenario.
It depends on the track, the tires,drawbar etc. Heck I know guys who carry a notebook and write different weight placement combos down. You will never get it exactly correct for each and every pull. Good luck..... .
jd b puller
02-23-2005 16:41:59
tires can make a huge difference. Cut tires will bite a heck of a lot more than uncut tires. If you can't get bite, you can't pick the front up no matter how hard you try. Like said earlier, see what everyone else is doing in comparable classes.
Dave in MN
02-23-2005 16:28:18
All depends on the track, size tires, hitch height, hitch length, how much motor you have. We use only suitcase weights because they are MUCH easier to move around. The best is to watch other tractors like yours and see how they are weighted. If you tractor is bone stock, 7500# class might be pretty tough for it. Good luck.
super_m
02-23-2005 18:01:39
 Re: weights in reply to Dave in MN, 02-23-2005 16:28:18
my tires are 14.9's.track is loose,doent pack good.hitch is 21 inches from center of axel,18 inches high.have any suggestions?
flyin farmer
03-01-2005 19:35:33
 Re: weights in reply to super_m, 02-23-2005 18:01:39
The best thing you can do is balance that trator. Trial and error is the best thing you can do. I pull a super m with 14.9's on a loose track also and suitcase weights are the best thing I have found to use. I can easily move them from front to back. You want a little front end lift-just let it bounce up and down barely touching. It is going to be very hard with wheel weights to get that kind of result. Wheel weights are great in the field but not so great on the track. Plus you will be smashing some fingers this summer moving those things.
I can pull the 7500 class but dont find it worth it. Pretty hard to beat a 706.
Good luck.
