JD spark plugs
ES
02-22-2005 16:50:32
What a good spark plug to run and heat range for ahigher comp motor and timing
JDGnut
02-23-2005 17:13:24
 Re: JD spark plugs in reply to ES, 02-22-2005 16:50:32
I'd get a set of plug adapters.. they will come with a sheet with different heat ranges... The adapters will cost only a few $ more than a set of big plugs.. REAM Corp sells the adapters... JDGNut
buickanddeere
02-22-2005 18:57:54
3116 Autolite is non reissitor and hot enough not to foul when idling while waiting your turn.
jugs
02-22-2005 19:04:05
 Re: JD spark plugs in reply to buickanddeere, 02-22-2005 18:57:54
I ran the autolite 3116 plugs. Put in a set in the spring and ran the same two-yes, only two, all season long. Never had to change once. Own enough stock in Champion plugs!
jd b puller
02-22-2005 18:43:33
I use AC 88.
