IHC heads
Oklahomatractorrebuilder
02-21-2005 05:03:32
What is the difference in the M heads with the casting numbers #8060DA and #8574DB ? Have some of both but not sure which one to use.
ChadS
02-21-2005 09:11:00
 Re: IHC heads in reply to Oklahomatractorrebuilder, 02-21-2005 05:03:32
Almost identical. The 8574 head is the late model gas head for the SM-MTA used on gas, and LP engines from the factory. No, its not an actual LP head, the 8060, was the older high compression gas head for the M's If your 8574 head has the indention along the side of the compression chamber, it is a good cyl head, compatible for firecrater, or stepped head pistons. You could get them either way, depending on what year the tractor was, early 52-late 53, there was the 8060, and the 8574d the DB is the late model prefix, so it should have the indention I mentioned,, ChadS
superih
02-21-2005 10:44:03
 Re: IHC heads in reply to ChadS, 02-21-2005 09:11:00
What is the casting for the 400-450 gas head? I thought that the late model SM through 450 were all 8060. What is the casting for an LP head?
SMTA PULLER
02-21-2005 14:48:53
 Re: IHC heads in reply to superih, 02-21-2005 10:44:03
Casting 400,450,is 362174R, LP head 364586R
superih
02-21-2005 14:55:52
 Re: IHC heads in reply to SMTA PULLER, 02-21-2005 14:48:53
You are listing the part number correct? What is the difference between the casting number and the part number. Is the 362174R still an 8060XX? Thanks.
SMTA PULLER
02-21-2005 16:26:47
 Re: IHC heads in reply to superih, 02-21-2005 14:55:52
The numbers i give you are the casting number.
courious about M heads
02-21-2005 19:10:38
 Re: IHC heads in reply to SMTA PULLER, 02-21-2005 16:26:47
I have a M with #8704DB what is it
