Oliver 80
Green 88
02-20-2005 08:34:33
A friend of mine just bought an Oliver 80 that he wants to set up for pulling. He was wondering what he could do to get more power out of the motor, bigger pistons, head, carb? Any help would be great.
Thanks, Green 88
James Tierney
02-22-2005 11:22:48
 Re: Oliver 80 in reply to Green 88, 02-20-2005 08:34:33
I just finished an 80, and may be able to give you some ideas - let me know what kind of power you are looking for, and I will assist if possible.
Green 88
02-22-2005 18:06:23
 Re: Oliver 80 in reply to James Tierney, 02-22-2005 11:22:48
How big can you go? We can run 10% over and 3.5 mph.
James Tierney
02-24-2005 10:58:27
 Re: Oliver 80 in reply to Green 88, 02-22-2005 18:06:23
There is a lot of room in an 80 - I have been looking at designs over 600 cubes, but you should not need to go that large with a speed limit. Let me know what you are looking for, and I will try to help.
Green 88
02-24-2005 11:19:15
 Re: Oliver 80 in reply to James Tierney, 02-24-2005 10:58:27
What would you have to do to get to the 100 to 115 h.p range?
James T
02-26-2005 14:35:54
 Re: Oliver 80 in reply to Green 88, 02-24-2005 11:19:15
At 10% over on an 80, you will probably need 500 cubes to make 110-115 horsepower. You will have to bore and stroke it.
Cody
02-20-2005 10:10:43
We had an 80 pulling tractor about 5 years ago. The worst part of an 80RC is no electric start. Put an M Farmall dist. on it, bolts right on, easier to start and gives it about 7 more HP. The one we had was about 490 cid.
ChadS
02-21-2005 08:54:15
 Re: Oliver 80 in reply to Cody, 02-20-2005 10:10:43
Cody, do you have any parts for Ollie 88? Im looking for a mild 85-100 hp, farm stock, stock rpm. I have a good crank, looking for a bigger bore sleeve and piston set. 4 inch would be good. Stock stroke, it already has the overbore 3-3/4 kit, in good shape,,, wanting to get that 88 sitting out back running this summer. Id do some trading if you have anything! ChadS
Cody
02-21-2005 21:20:27
 Re: Oliver 80 in reply to ChadS, 02-21-2005 08:54:15
Chad, I don't have anything right now. You can probally find a set of 3 7/8 M&W pistons and sleeves pretty easy. With a little head and induction work, 80HP is achievable.
