Tire Baking - Where????
Redpuller
02-18-2005 17:40:38
Where can I get some new tires boiled or baked and how much should it cost?
ollie88
02-20-2005 14:26:09
 Re: Tire Baking - Where???? in reply to Redpuller, 02-18-2005 17:40:38
I did some checking with some friends who pull 9500 ss and they dont bake the tire's they run and also called a mod puller and he spins them 130 mph and they are not cooked either so I guess I dont think we need them on our antique. The old oliver just dont have the wheel speed!! As far as bars folding cant believe that would happen. If you got a good cut job and run the right air they should hook up just fine. Just my opinion!
Mopuller
02-20-2005 10:58:41
I am interested in the process behind this. Is there any information available? Thanks. MP
wanna be puller
02-20-2005 07:56:52
how does a harder tire pull better?
770
02-20-2005 09:02:41
 Re: Tire Baking - Where???? in reply to wanna be puller, 02-20-2005 07:56:52
The bars won"t fold under on the track which causes slippage. The only drawback is on a loose track they will pile dirt in front of the sled.
ollie88
02-20-2005 07:01:23
Does anyone have any data to show baking helps?chemist at local firestone factory says it really doesnt make a difference. Just wondering
merle
02-19-2005 18:01:29
will be gone until mar 10 will be baking tires from then on Thanks Merle
russ rolke
04-23-2005 19:54:32
 Re: Tire Baking - Where???? in reply to merle, 02-19-2005 18:01:29
is ther a phone number that i can get a hold of someone thanks
Redpuller
02-19-2005 18:19:38
Merle, Where are you located and how much do you charge. Have a new set of 16.9 x 38 to get hardened up. Thanks.
merle
02-20-2005 06:33:50
 Re: Tire Baking - Where???? in reply to Redpuller, 02-19-2005 18:19:38
located big rapids mi on new tires like the 16.9x38 would have to run them thru at least twice to harden enoughwould have to check hardnessafter each run if two runs $250 if single $150 this is for the pair Merle
DCPULLER
02-19-2005 17:50:56
Redpuller, in southern WI they do them for $300 a pair. If new tires somtimes they have to do them up to 3 times. DCPULLER
