mm 5 star
jeffw
02-18-2005 17:04:04
what can i get a 5 star down to without aluminum parts 6000????? 5 star diesel wide front 15.5x38
Roger66a
02-25-2005 18:55:42
 Re: mm 5 star in reply to jeffw, 02-18-2005 17:04:04
We have a guy in our area that pulls a five star in 5,000 lb class. He does have the narrow front on though. No aluminum.
Boyce Seaman
02-20-2005 18:05:31
I don't pull a 5 star, just U, and ub. Since no one has answered I'll give an opinion. I would say 6000 is within reach, but you won't have much if any moveable weight. If you take the hydrolics, fenders, and anything else you don't need off that would allow you to put that amount on the front where you will need it. Different areas pulling conditions very a lot, sticky, loose, sand and so on. In this area a stock gas UB will be low on power, an ampitoque would obviously give you a lower gear. Give it a try let me know how you do.
jeffw
02-21-2005 05:54:20
 Re: mm 5 star in reply to Boyce Seaman, 02-20-2005 18:05:31
i should have around 75 hp so i dont think hp will be a problem in 6000 stock thats 200 more rpms same as 670 super and tweak inj pump maybe 80 hp
