Reground cams
Shaggy
02-17-2005 10:43:34
What do they actually do to the cam when they regrind them or should I say where do they get the extra material to add lift and duration? Do they weld them up and reshape the lobes?
Thanks Shaggy
buickanddeere
02-20-2005 16:39:57
 Re: Reground cams in reply to Shaggy, 02-17-2005 10:43:34
Even just bringing the cam back to stock specs can bring pretty good HP. A cam and follower set may look OK to the eye. However when measured, they are robbing torque from less duration and lift caused by wear.
REDEYE
02-17-2005 11:06:12
they get the extra material from making the base circle smaller. dont forget that by grinding the base circle just .05 you can get up to about .1 more lift due to the rocker arm ratio. In some extreme cases you can weld the lobe and grind it, however, it is much easier to just turn the shank of the cam down than to weld the lobes.
Shaggy
02-18-2005 22:15:37
 Re: Reground cams in reply to REDEYE, 02-17-2005 11:06:12
Would I be better off buying a set or Roller rocker arm's? I know it would be easier to change.
CASEPOWER
02-19-2005 07:13:47
 Re: Reground cams in reply to Shaggy, 02-18-2005 22:15:37
You only gain lift from rockers. There is much more to grinding the cam. Duration, lift, lobe seperation, and intake lobe advance will be changed when grinding a performance cam.
CASEPOWER
02-19-2005 07:13:35
Shaggy
02-19-2005 15:40:45
 Re: Reground cams in reply to CASEPOWER, 02-19-2005 07:13:35
So the 2 together would be a pretty good set up. I have 1 more engine to redo and I would like to make it a good one!!I better work a bunch of Over time!
jd b puller
02-20-2005 10:28:57
 Re: Reground cams in reply to Shaggy, 02-19-2005 15:40:45
Shaggy: You wrote:"So the 2 together would be a pretty good set up. I have 1 more engine to redo and I would like to make it a good one!!I better work a bunch of Over time"
Be careful what you do. Big valve lift has its place. Make sure your motor desrves it or it won't have any umph.
And work lots of overtime while you can.
