battery question
Mike Aylward
02-16-2005 17:37:51
I have a "theoretical" question for everyone. Many pulling associations specify that a battery be "covered". If a person uses a gel-type battery such as an Optima (which, according to their website, says it won't leak even if cracked) will it need to be covered? Mike
possible fires
02-16-2005 19:04:26
 Re: battery question in reply to Mike Aylward, 02-16-2005 17:37:51
Its not the fluid they worry about but the sparks from the exposed terminals. Alot of tractors run batterys and small fuel tanks on the front ends next to each other.
Panhandler
02-17-2005 19:52:06
 Re: battery question in reply to possible fires, 02-16-2005 19:04:26
If the battery is 5 ft behind the fuel tank and there is an electrical fire at the starter(The most likely at start up) it will be roaring pretty well before you can get the cover off the battery to disconnect the cable.
