Farmall A
Louis Z
02-16-2005 15:16:40
Wanting to make a puller out of an Farmall A and need to know if anyone out there knows how much i can mill off the head using dome pistons from Tisco. Also if anyone knows who can cut the cam for low end torque? Any info would be greatly appreciated.
Augie
02-17-2005 09:15:02
 Re: Farmall A in reply to Louis Z, 02-16-2005 15:16:40
Also try to come up with a governor off of a combine motor. The flyweights are about half the size of the weights in the tractor governor. Makes a world of difference...
CLIFF
02-17-2005 05:57:54
The dome pistons are a good package with the stock head cut .040 to .060 BUT an 140-340 head is better, Its like a LP head for a H or M, I would use a 140 to 340 cam (C-153 same cam) head amd manifold(unless your culb requires stock head and manifold, check rules first)with thoes pistons and 140 head you will need 94 oct gas and hope it dont get hot in a hard pull without a water pump. CLIFF
Shaggy
02-17-2005 01:24:18
I have a B with the tisco Hi domes and a 3 1/8 bore with a 140 head. The head has been cut but I am not sure how much as for a cam mine is stock for know but I was looking at one out of C-153 engine. It came in stuff like a 404 or a 504 and some combines and balers. I think I am right on the 404 and 504. I have to double check.
Hobo,NC
02-16-2005 17:38:52
I am no expert but I would look fer a 140 head and cam and you will be way ahead of the ball game. i would say you kin cut down a A head a bunch. My experience has been with the 123 engine and not the 113 engine Hope this helps.
WILDMAN
02-17-2005 04:46:57
 Re: Farmall A in reply to Hobo,NC, 02-16-2005 17:38:52
PREACHER CAN CUT YOU A CAM. 336-584-8254.
