Stock MM UTU weight distribution
savsmm
02-15-2005 09:26:15
I am going to start pulling this summer and have a question about where to start with adding weight to my U. Stock class, stock drawbar, transfer sled, 3 mph. I know I will learn as time goes on, but for my first time out, where do I start with adding the weight to get to the class weight, then to the next 500 lb class. Front? (can not go further out than front part of tractor), middle?, rear?. We can use suitcase weights. Thanks. Chris
LW
02-15-2005 18:15:36
 Re: Stock MM UTU weight distribution in reply to savsmm, 02-15-2005 09:26:15
In front of rear axle housing you amy want a rear weight bracket and a belly bracket also give it some time you'll get it hooked up. That sotck you will want the front end up the last few feet of the pull a couple inches.That when you have it hooked just right.
