More power out of an unsyled A
Green weenie
02-14-2005 13:14:22
After many hours of discussion on this forum pertaining to this subject I have discovered that if you do not want to spend any money and you want to get that big horse out of a stock A, the only way to do it correctly is to buy a "G"
BushogPapa
02-15-2005 06:57:00
 Re: More power out of an unsyled A in reply to Green weenie, 02-14-2005 13:14:22
Yes..!!
A "G" is like an "A"--ONLY Built to "Military Standards"...!!!!
Like a Harley-- "Built to take-- ANYTHING"..!!!
Ron.
49 A
02-15-2005 17:04:25
 Re: More power out of an unsyled A in reply to BushogPapa, 02-15-2005 06:57:00
Yes, this is very true--if you do not want to do much motor work, a stock G will walk all over a stock A. However, one thing to bear in mind is that Gs are much harder to come by than an A, and they also carry a much higher price tag. Also, G parts are much spendier than their A counterparts. For the difference in price, you could be well on your way to buiding a very stout A.
Either one is a great choice for pulling, it is more or less just a matter of which weight classes you are looking at pulling. If you set up an A and a G with the same weight braketry, comparable starting system, and identical wheels & tires, the A should be around 700 pounds lighter.
Truth of the matter is that no matter which tractor you choose, or even which color, it takes $$$ to make power.
jugs
02-15-2005 20:42:03
 Re: More power out of an unsyled A in reply to 49 A, 02-15-2005 17:04:25
Tony, Tony, Tony, Give it up! You're gonna get spanked. Let the man buy a G if he wants. Geez, go study a book or something!
