Puller needs to go on a diet
mattt
02-12-2005 21:12:43
I have a 1955 IH 300 row crop that i pull in stock class. It has 9 boolt hubs with pressed rims. Standard rims on the front. With a 200 pound driver on it it weighs about 4250 pounds. I would like to get into the 4000 pound clas. The pto is gone and so is all the hydraulics. What can i do to get her lighter? Is there a front end off of something that bolts on so i could use pressed rims?? Is anybody making a aluminum top cover? How about weld on axel hubs? It has a 2 1/2 inch axle. Thank you.
770
02-13-2005 12:25:40
 Re: Puller needs to go on a diet in reply to mattt, 02-12-2005 21:12:43
Recently replaced my 50 lb. battery with a 30 lb. one.....That's 20 lbs??
thejdman01
02-13-2005 10:55:37
dont count on it they dont have to and no guarentee but most and i say most tracks i go to will give you 100 lb leeway to compensate for scale innaccuracy. most will give you 100 lbs (4000 lb class they will give you basically anything under 4100. ) not all but some. i have seen them let in a 4300 lb tractor in a 4000 lb class the guy literally took a cab off too everything off he coudl and they let it just cause he worked so hard. most people are jsut out there to have fun theres always somone who will gripe and break the rules but thats the world today
thejdman01
02-13-2005 10:42:45
my experience is stripped tractors dont pull well. you have no way at all to balance it get some more weight on the back balancing it to get the front end where you want it etc etc. you can try it but may not have good luck. some tractors stock stripped are balanced better then some. also lincoln lock the rear if your running open diff's w/o a diff lock.
ChadS
02-13-2005 08:13:34
I agree, weld on hubs are a must have. If you are running the big cast 300-350 hubs,(on the front) find a set from maybe a utility that had pressed steel wheels. Seek out "Ohio M Puller" on this pulling board, he builds lite weight front pedistals that are pretty strong. He has them complete with wheels, or not,,, Does it still have power steering? Mite consider getting rid of it, and use aluminum for the steering shaft. Maybe also a lite weight seat assembly. Hope this helps, ChadS
jd b puller
02-13-2005 08:41:21
 Re: Puller needs to go on a diet in reply to ChadS, 02-13-2005 08:13:34
Do some places NOT let you run the weld on hubs? Or certain divisions? Curious, thinking about it on mine.
Jerry Cent. Mi.
02-13-2005 05:19:43
Weld on hubs would save you some weight.
mattt
02-13-2005 15:17:19
 Re: Puller needs to go on a diet in reply to Jerry Cent. Mi., 02-13-2005 05:19:43
where do you find weld on axel hubs for a 2 1/2 inch axel?
