more power from an A
john deere pull
02-10-2005 16:29:52
I am working on a unstyled A I put high compression aluminum pistons in it so far but would still like some more power. I have thought about a styled crank but dont know if I want to go that route and was told that it will not work with my pistons. What else can I do to get some more power from my A. I would like to get 35-40 horsepower. Any help or suggestions would be appreciated. THanks
Farmall whupper
02-11-2005 14:19:38
 Re: more power from an A in reply to john deere puller, 02-10-2005 16:29:52
How much can you bore a 71?
jd b puller
02-12-2005 14:51:11
 Re: more power from an A in reply to Farmall whupper, 02-11-2005 14:19:38
I wouldn"t rec boring a carb, especially since there are bigger ones out there... Big nut G for example. You may pass more air thru it, but if you screw up the venturi effect, you just slobber the fuel in there, not atomize it.
hooked
02-11-2005 12:46:06
Change the mag to a distributor with electronic ignition and a hot coil. Change the carburetor to a big nut G carb. and bore out the carb.
J.P. Dunn
02-10-2005 21:38:36
Take 6 3/4 crank (styled A) and have it offset ground 1/4" (resulting in 7" stroke). Have JD 329 rods mated to your rods or have custom rods made. Assuming you have no ring groove, make rods as long as possible. Sparkplugs will limit how far forward pistons can travel. Will increase cid, compression, and torque. Can all be done for under $500 with welded rods (depending on where you get the late A crank).
JerryBird
02-10-2005 16:58:33
I would suggest giving Triple G Service a call.They have devoted a huge amount of time in research to help make our old 2 cylinders perform great(modified and stock).Fine folks to deal with ,for parts and advice .Their toll free number is 1-888-720-0830.
