B model power block
red man in a gr
02-09-2005 17:42:19
if you look at a power block on a b jd you'll see 5''- 1 or 2 or 3. i think the 5'' is bore but what does the other # stand for? and what is the difference in the different #? can some one explain.
WTW
02-09-2005 18:17:20
 Re: B model power block in reply to red man in a green world, 02-09-2005 17:42:19
Red, There were three 5" bore Power-Blocks available. The 5-1 was intended for 1941 through 1946 model "B" tractors. The 5-2 was for 1947 through 1952 model "B" tractors. The 5-3 was for the model "50" tractor. All three blocks used the same pistons. All three blocks are basically the same casting only machined and drilled different for the different model change / applications. I have a 5-2 that I would trade for a 5-1 if anyone is interested. DW
