pistons
jeffw
02-08-2005 19:55:18
which is better firecrater or step
ChadS
02-09-2005 07:42:56
 Re: pistons in reply to jeffw, 02-08-2005 19:55:18
With M heads, stepped head pistons, firecraters may hit the M head without reliving the area in the chamber where it will hit. Firecraters have a good turbulence, created in the cyl chamber and speeds up flow in the chamber. Helps HP, a cleaner burn in the chamber, and more torque and HP due to the design change. Stepped head pistons are compatible with both, old, and new style heads, firecratewrs, like the new head, and cam design found in the SM-450. It is a pretty good matched set up. ChadS
