TIRE AND RIM ?
BUCKMASTER
02-06-2005 18:58:50
WILL A 15.5 /38 GO GOOD ON A 16 INCH RIM DO MOST CLUBS ALOW THIS IT WILL BE ON A 52 SUPER M THANKS
LumbrJakMan
02-07-2005 12:30:48
 Re: TIRE AND RIM ? in reply to BUCKMASTER, 02-06-2005 18:58:50
Well the Southern Maine Tractor Club will allow it as long as your one of the: " Chosen Few" , all others will be hassled for even non stock Vavlve Stems . Now if your name is Lucien you can even pump your Motor up to 5000 RPM , and still enjoy the benefits of calling it "Stock " and pulling against Real Stock Tractors . That Man should save himself a lot of Money and just go downtown and BUY his Trophies !! Thats all there worth !!!
jeffw
02-07-2005 10:29:39
will work great it will flaten out your tread and give itmore even ground pressure across the tread
DP
02-06-2005 19:34:01
Better check your local clubs rules. In this area you would have to use a 14" rim at most. Don
jasonn
02-06-2005 19:01:48
sure it will i got a 14.9 on 16" works great. Use large tubes though tore one of mine first try.
