oliver 77 how much hp can i get out of it
chot
02-06-2005 17:31:10
i have a77 with a88 motor in it how much horse power can i get out for about 2000.00 and where i am in new jersey i can pull 3 gear in 4500lbs class all ready thanks charlie
stroker 88
02-06-2005 18:39:49
 Re: oliver 77 how much hp can i get out of it in reply to chot, 02-06-2005 17:31:10
what is in it now? what rpm's are you allowed?for the 2000 you are probably looking at some over bore and head and manifold work.
chot
02-06-2005 19:36:05
 Re: oliver 77 how much hp can i get out of it in reply to stroker 88, 02-06-2005 18:39:49
i have a stock motor out of a 88 in it know rpm are open thanks chot
stroker 88
02-07-2005 17:02:42
 Re: oliver 77 how much hp can i get out of it in reply to chot, 02-06-2005 19:36:05
with open rpm's i would stay with stock stroke. put a set of 3 7/8" kits in it. bigger valves and some port work. be careful some of thoses heads are thin under the valve seat area. try to find a larger carb. don't let anyone talk you into milling alot off the head. the surface will get thin, then when you do get the compression up it's hard to hold a head gasket.
