positive ground to negative ground
JdG1950
02-05-2005 06:33:40
How do I switch my 1950 "G" from positive ground to negative ground and switch from generator to alernator?
Thanks for your help ! JdG1950
730-LP
02-05-2005 20:25:57
 Re: positive ground to negative ground in reply to JdG1950, 02-05-2005 06:33:40
Go to the John Deere board and post your question there,in the subject line [Wiring question for John T]
jpl300
02-05-2005 06:45:25
 chads, need 300 parts, in reply to JdG1950, 02-05-2005 06:33:40
chads need your phone #. would like to hop up the 300, its a 1955. I ran at iverness with the 52 m, was a great track, especially the warm weather.
ChadS
02-05-2005 08:43:28
 Re: chads, need 300 parts, in reply to jpl300, 02-05-2005 06:45:25
email me if you like, or call 574-893-7437 shop, or 574-893-1032 home phone. Thanks. ChadS
jpl300
02-05-2005 10:04:49
 Re: chads, need 300 parts, in reply to ChadS, 02-05-2005 08:43:28
Thanks Chad, have to go on a run to ga. will get ahold of you later, need the 350 bore kit, gov spring. have a 55 300, early #, but wait to get apart see if big wristpins or small. hey, got beat in fla by a 460. but my cousins 52 m won the pull. we run the super antique pull. was a alot of tractors there. packed sand and 3 sleds running. smokers and v8 tractors there too. best i did was 6 a couple times in 6500 and 5500 class my m powers out. in ohio here will get ahold of you later, thanks
