Question for Chads
cliff Bice
02-05-2005 06:07:25
Which in your opinion is better for a pulling stock tractor a mag or distributor? Thanks Clif
ChadS
02-05-2005 06:13:51
 Re: Question for Chads in reply to cliff Bice, 02-05-2005 06:07:25
Mags can be alterd a bit to give a real hot spark, they are pretty hot already. they are slow in response, but if the mag works well, they are dependable. I prefer the distributor on pullers, if you ever do the swap, you'll see the difference between the two set ups. Have to do some wiring to add the distributor. The distributor helps these engines alot! They run much better. ChadS
