How much airflow is too much?
REDEYE
02-04-2005 16:21:50
ChadS post about porting got me thinking about all kinds of stuff to do this winter. But before i begin i was just trying to figure out a limit so i wouldn't overdo it. The engine is a 281 with 170psi dynamic compression. The most rpm's this motor will ever see is about 2500. the head is a stock 450 with the only work being a manifold to head port match. I have seen advertisements for an all out porting job with big valves and I am just wondering if this is really needed? I dug out the old fluid mechanics book and this engine should need 50.75 cfm per cylinder. compare this to a 350 chevy turnign 6000 which needs 75.9 cfm per cylinder and you see that the old 281 needs a lot of air, but im guessing that the heads on them dont flow a third as much as the chevy heads do, not to mention the really small cam in the 281. I have heard that increased ratio rockers and bigger cams do not gain much power on this type of motor. Is that because the heads dont flow well above a certain lift or that the engine dosent need anymore air? does anyone have cam specs or flow bench data? i have half a notiion just to get that old head flowed to see what it has, as well as laying out the cam spec. then write a little program in matlab to see how much air is actually going into the engine. also what kind of vacuum do these engines draw? typically automotive applications are rated off of 24" of water, what about tractor engines? thanks in advance
ChadS
02-04-2005 20:15:58
 Re: How much airflow is too much? in reply to REDEYE, 02-04-2005 16:21:50
Redeye, I've had alot of M-450's on the dyno, from the earliest model M, right up to the late 450. Ever notice how the 281 has its own sound to it? I mean, ideling, it dont sound like no M! I have one in the shop right now that is getting the engine redone, up to 306, with a stroker. All I can say really about the 450,(281) is that is a sleeper. Stock, these were very strong engines, the strongest for the entire history of the engine style. The later IH 4 cyl, from 1954, up to 1957 had alot of internal casting changes to improve the HP and torque, as well as being somewhat efficient to run. They had the science right, but HMMM,,,, wasnt efficient to run as for fuel economy, so they ran a low compression ratio. That made them a bit better on the fuel. Lower compressed engines dont need as much fuel. They can breathe all the can handle, or all the cyl design can draw into the cyl. The ports on them were much more straight through VS the old M heads, and they found out that the old M cam would not run right with the new head design, so they added a cam to match the head. then the power seemed to come alive on them. The intake manifold was bigger, as well as the venturi, and the carb throat size up as well. The basic 450 had flat top pistons, and if it was lucky, it had 125 psi of compression, but at 281 ci, with all the upgrades, from the factory, not anything I did, just dyno it. it was strong, the one that is in the shop is at 63 hp, and it will lug the needle down on the dyno farther and longer than any M would, at 150 psi and the old head and cam, and 4 inch bore high compression pistons was only 55!! My opinion if a 450 head can flow more than what it has, Absolutly! Im not a scientist here, but Id say the volumetric efficency kida blows when the compression is way down on them and not even close to the potential they were designed to be. The different ratio rockers? To me, it is a way to gain a bit more lift, but if you have no compression to compesate the changes, it does nothing!!! in order for an engine to require a different cam grind, is when it is lacking something preventing improvenmet, like a big cam, in a low compression engine, thats like running a 7 inch stroker in a M or 450 and have only 175 psi of compression. Your backing up if you dont have the factors to warrant such a change. You mentioned that you gasket matched your head, well it did not do much, sure it gave it more flow, but the compression did not increase. These engines need compression to gain. The science is already there, the set up is very very good in the C-281. Just give it some compression, and turn a monster loose! Just remember, 63 hp, 281 cubes, 125 psi of compression. wonder what it would be, if it was, say, 185, 190, 200 even? Tell you what,, ask someone who has a C-281 450, that is running an LP head and it is running right, find out what they get for HP if they have dynoed it. What do you want to know about a 450? Im tearing it down next week to install the stroker! ChadS
Drew
02-04-2005 17:36:02
The high ratio rockers arms WILL help because you not only are you opening the valve farther, you are holding it open farther for more time. You are correct that a cylinder head is done gaining airflow after a certain lift number. If the head will support it, the high lift will help you, but even if your head quits at .xxx" lift, the valve is still open longer at lifts it does flow well at and will allow more air into the engine.
REDEYE
02-04-2005 18:06:30
 Re: How much airflow is too much? in reply to Drew, 02-04-2005 17:36:02
your right on about how increased ratio rockers should allow more flow, although some cylinder heads do drop off in flow at higher lifts, high reynolds number perhaps? but what i was referring to is that increased ratio rockers dont help a stock 281 much and was wondering what was the "bottleneck." even though the valve is opened a greater distance and more area is under the cam profile there seems to be relatively no effect on power. so do these heads flatline on flow above a certain lift, or perhaps even drop off? or is there some underlying factor that causes this situation to arise?
