John Deere G stock 40 hp?
Mike S 806/H
02-04-2005 15:29:06
Does 40hp from a stock G sound right? It has fresh rings and valve job and gas manifold. Just wondering how accurate my dyno is.
DP
02-04-2005 15:42:57
 Re: John Deere G stock 40 hp? in reply to Mike S 806/H, 02-04-2005 15:29:06
Hi Mike, Are the pistons still factory cast, or high compression? If you have the factory pistons and bore yet, its probably close to right. If your talking gas pistons, then it sounds a little weak. How is it set up? Don
Mike S 806/H
02-04-2005 15:47:38
 Re: John Deere G stock 40 hp? in reply to DP, 02-04-2005 15:42:57
It has stock cast pistons std bore the rings are fresh probley 1/2 hr run time. Also has the styled 551 head and a gas manifold
DP
02-04-2005 15:50:39
 Re: John Deere G stock 40 hp? in reply to Mike S 806/H, 02-04-2005 15:47:38
With the stock bore and cast pistons, your about where I'd expect it to be. Did it have any ring groove? Don
Mike S 806/H
02-04-2005 18:14:20
 Re: John Deere G stock 40 hp? in reply to DP, 02-04-2005 15:50:39
There was some ring groove.
ChadS
02-04-2005 15:38:48
I had a G in here this past summer was 45 hp, that was with a .125 kit in it. 100 psi of compression. ChadS
