Sealing sleeves in wet block
sleeve
02-04-2005 07:38:05
Ok, here is the skinny. I am putting JD sleeves in a Oliver 88 block. They have been turned down to a 4.550 OD, .150 thick. There is no step at the bottom, fashioned after traditional hand-set sleeves with o-rings.
Question: should I have a o-ring cut into the sleeve ans use o-ring?
Could I simply use high heat silicon as a sealer without the o-rings?
Anything else I could use to seal?
We Know
02-05-2005 12:46:52
 Re: Sealing sleeves in wet block in reply to sleeve, 02-04-2005 07:38:05
bozo, if you just take it to a reputable machine shop. you wouldn't have to do all this r&d and ask such dumb questions.
we all don't have connect
02-05-2005 15:27:21
 Re: Sealing sleeves in wet block in reply to We Know, 02-05-2005 12:46:52
Just to stick up for the original guy. Most "reputable" machine shops don't know $hit about tractor pulling, much less how far you can push the envelope. Any good shop can do machine work, but let's face it, everything we do is custom and out of the ordinary. You could be a lot more help to this guy if you could point him to a reputable (tractor pulling) shop instead of just shooting your mouth off.
We Know
02-05-2005 18:28:19
 Re: Sealing sleeves in wet block in reply to we all don't have connect, 02-05-2005 15:27:21
the question he is asking we'done for years. so have the others who answered him. we are just having some local fun. sounds like you need to get a sense of humor or something else to do. i see you gave him lots of help.
mEl
02-05-2005 05:44:30
I use 4 5/8 2290 sleeves in my DC turned down to .137 thick, Two 1/16 orings in grooves on the sleeve work nicely for me. mEl
stroker 88
02-04-2005 19:01:36
use a 1/16" viton o-ring, have the block machined for it.
Earl S.
02-04-2005 10:39:31
I use 1/16 "O" rings 2- 3ea on each sleeve or press fit sleeve at btm.email for details. Earl
CASEPOWER
02-04-2005 09:08:18
I would have the block machined for O-rings. If you machine the sleeve that is .150 for a .125 O-ring, your gonna have problems. Robert Sox in SC can cut the O-rings in the block. I am not sure who else does it. I have heard of people just using sealer, but if there is room, block o-rings would work best.
