Rear End Heft 335 M-M?
Mopower
02-03-2005 10:34:42
These differentials are smaller that 445 etc. By the looks of them they look built well. How do they hold up? Crank the power to them? How well do you think they are built for their size. I know a model R is weak if you double the h.p.
JK2
02-04-2005 06:17:51
 Re: Rear End Heft 335 M-M? in reply to Mopower, 02-03-2005 10:34:42
The cross shaft in the differential is smaller than a 445 & have seen them break. We run a brass block between the ring gear and the front of the rear end case, bolted to the rear of the transmission case, to keep the ring gear from trying to move away from the pinion.
John
