Farmall H bore
Farmall H Pulle
02-03-2005 06:02:07
How big of a bore can you get out of an H . How much power would you have with a little carb work and some other stufff like that.
RK
02-03-2005 15:15:06
 Re: Farmall H bore in reply to Farmall H Puller, 02-03-2005 06:02:07
I put internationsl 350 pistons 3 and 5/8 bore a, ported and polished my head bigger valves,decked the block, milled the head, and a few other small items and I am getting 48 hp, might not sound like alot of hp but the motor pulls 2nd gear on most tracks in 3500, and really puts the power to the ground.
cshaffer
02-03-2005 07:05:32
Do you want to run sleeves in it or you can go bigger and run against the cast wall? Email me if I can help.
ChadS
02-03-2005 06:10:20
3-13/16 is about the max bore you can go with the H block. Id would hard block it, up to the bottom of the water plate if you go out that far. You will have to stroke it to go that big, I dont know of any other pistons that will work with stock stroke, until you get up to a 4 inch bore. H blocks cant go that large. 300-350 blocks can, but real thin too. ChadS
