Rim Width Rule For Local Club
Marty in Mi.
02-02-2005 14:54:44
Our local club has rim width rules that in my opinion are out-dated and just plain silly.They are as follows:
2500#-10 inches
3500#-11 inches 4500#-12 inches
5500#&6500#-14 inches
Our tire rule says that you can run up to a 15.5 x38,or if your rim is 33 inches or smaller,you can run up to a 18.4 width tire in all classes.Can you imagine what a B Allis might look like with a 18.4 tire on a 10 inch rim?I told them at our last meeting that we should just throw out the rim rule and let each puller run what ever they want for rim width,but we had a tie vote,and our president chose,for some unknown reason, not to cast a vote that would break the tie,so it was tabled until the next meeting.Another option might be to allow what ever rim width the tire manufacturer allows for that particular tire.My thinking is this:The less rules you have,the better,and the ones that you do have should be easy to enforce.This rim rule also opens us up to potential lawsuits,in that if someone tries to put an 18.4 on a 9 or 10 inch rim and the tire blows off the rim and hurts them,who,then,is responsible?Certainly not the tire manufacturer who clearly labled their tire.That is probably not going to happen,but the what if still exists.If we don't change something for the better,does anyone know where we can find some sort of a caliper/micrometer to measure all rims at every tractor pull AND THEN kick out about 40% of the pullers?
What do ya'll think,Marty
Bus Man
02-02-2005 16:33:56
 Re: Rim Width Rule For Local Club in reply to Marty in Mi., 02-02-2005 14:54:44
I wasn't at the meeting and I don't pull under 5500, so I've never thought too much about rim size in the lighter classes. I do think that if you're going to have a rule, you should enforce it or do away with it. If you don't, it makes it too easy to cheat and then everyone's doing it. Where does it stop? As soon as you single someone out you've got trouble. As far as the voting went, if the club follows Roberts Rules of Order, there are no "ties". If the motion did not get a majority of the votes, the motion is defeated. The person running the meeting normally does not vote if it's a voice or hand vote. He can vote if his vote will change the outcome. ( In this case he could only vote "for" the motion which would give it a majority and pass the motion.) Ballot voting is different. But since the membership voted to table it that action stands. That's my 2 cents for whatever it's worth.
