john deere G pullers
JDG70
02-02-2005 09:42:54
Does anyone know how many cubic inches most of the G pullers are running and what's the biggest one anyones heard of. I heard someone is building one that is going to be over 1000. Just looking for some thoughts on this topic.
T-Rex Pulling Team
02-07-2005 16:03:05
 Re: john deere G pullers in reply to JDG70, 02-02-2005 09:42:54
I know where there is a G that will be 1,200 CI.
THJD
02-02-2005 10:49:10
A G just sold in PA that was approx. 883 cu. in. I believe Schellums have one approx. 1000 cu. in. There is another G in Kimball, MN at about 900 cu. in. These would all have to be at or about 10" of stroke and 7.5" bore. Once you get over 6.375" bore and 9.25" stroke, it takes ALOT of work and $$$ to make gains.
two extreme
02-02-2005 12:59:04
 Re: john deere G pullers in reply to THJD, 02-02-2005 10:49:10
two extreme is 10.5" x 7.75" or 991 cubes.
Jerry Cent. Mi.
02-02-2005 13:10:30
 Re: john deere G pullers in reply to two extreme, 02-02-2005 12:59:04
Just my observation but these tractors don't live through a lot of pulls. I know that some will not agree but I don't see these tractors lasting very long around here.
yeah
02-02-2005 19:55:49
 Re: john deere G pullers in reply to Jerry Cent. Mi., 02-02-2005 13:10:30
you're looking at replacing some parts every so often, mainly bearings. In a G as big as Two Extreme for example, unless you've got a billet crank (which it does) it could break while idling. Also you would need good rods and it's questionable how long the rings and cylinder walls would hold up.
observer
02-03-2005 06:55:27
 Re: john deere G pullers in reply to yeah, 02-02-2005 19:55:49
I dont see these tractors winning alot of pulls, especially for the money invested!!!!
buickanddeere
02-03-2005 08:19:55
 Re: john deere G pullers in reply to observer, 02-03-2005 06:55:27
It's a near mircale how they take an engine designed to turn at 975 rpms while burning byproducts. The stuff refineries used to throw out when these tractores were designed. Long, small dia, heated ports and eyebrow cylinder head intakes were required to keep oily fuels vapourized and in suspension. This is far from ideal to feed a high rpm big inch engine running Cam II gasoline.
A-Puller
02-03-2005 22:47:50
 Re: john deere G pullers in reply to buickanddeere, 02-03-2005 08:19:55
With all that work, can they run with the big MM'S in Div. 5 ?
buickanddeere
02-04-2005 15:26:59
 Re: john deere G pullers in reply to A-Puller, 02-03-2005 22:47:50
Maybe with a monsterous sized head and intake manifold from Jerrys?
