cam
redcub
02-01-2005 18:26:52
Got about 160 compression in each cylinder on my H farmall with stock bore and stroke. Would I benefit greatly from a different cam? What would Hp gain be? What else would change? Where do you get it? How much? Thanks.
buickanddeere
02-02-2005 08:24:19
 Re: cam in reply to redcub, 02-01-2005 18:26:52
As cam duration is increased the mechanical compression ratio has to be increased just to keep the same compression psi. The rpms where peak torque and peak HP are then supposed to occur higher. Along with higher peak torque & HP. Unless the engine's airflow can keep up at higher rpms, the torque & power gains will be little to none.
770
02-02-2005 14:20:18
 Re: cam in reply to buickanddeere, 02-02-2005 08:24:19
I agree. Airflow is the key. So many people dump cash on parts when a "simple" port and polish job done correctly will yield more power than they ever expected. Just my opinion.
ChadS
02-02-2005 06:27:03
It would help, since you are over 150psi, you wont see much of a difference in it, more torque, not A BIG HP gain, maybe 2 or 3, on an H. Have not seen a stock engine gain alot of HP by going much over a SH-350 cam in them. you get over 175 psi, then you might get a bit more results. ChadS
cshaffer
02-02-2005 05:23:09
You can pick up 5 to 10 hp with a good cam. Let me know, i can do that for you. 585-335-9274 or email me.
