SUPER M PISTONS
RONNEEE
01-28-2005 00:06:32
WHERE CAN I GET A SET OF "POP UP"PISTONS FOR A SUPER M? NO DENNY'S CARB SHOP!!!!! !!ANYWHERE BUT THERE. THANKS
ChadS
01-28-2005 06:17:03
 Re: SUPER M PISTONS in reply to RONNEEE, 01-28-2005 00:06:32
Ive got 4-1/8 bore high domed pistons, 574-893-7437, ask for Chad, or Earl. ChadS
ronneee
01-28-2005 10:14:19
 Re: SUPER M PISTONS in reply to ChadS, 01-28-2005 06:17:03
whats the compresion..do i have to bore the block? whe makes them? how much? thanks
ChadS
01-28-2005 11:27:11
 Re: SUPER M PISTONS in reply to ronneee, 01-28-2005 10:14:19
Compression ranges from 150-to 200 psi. No Boring the block, I make them, can be done as an inframe overhaul kit. Stock kits are cheap, high compression parts, Please call for the details. these stock bore, high compression piston kits can make 70-75 hp easily, basicly the same power output as if you were to bolt an LP head on your engine. Have stock bore stroker pistons too for the H-450 tractors. 574-893-7437, shop, 574-893-1032 home, call anytime. ChadS
JDGnut
01-28-2005 11:59:59
 Re: SUPER M PISTONS in reply to ChadS, 01-28-2005 11:27:11
Chads.. do you have a pic of the pistons you are making??? Just curious... You can email one to me... if you don"t want to post it... Thanks
JDGnut
ChadS
01-30-2005 08:10:21
 Re: SUPER M PISTONS in reply to JDGnut, 01-28-2005 11:59:59
JDGnut, yes I do. Ill send you an email later today, ChadS
