Tires????
DTpullteam
01-27-2005 16:27:19
Ok pullers,I would like your views on cut tires for stock antique or let's say a little over stock tractors. Max. size is 16-9-38. So what type of cut and hard side wall or soft is best? Also what's your pick of brands?
DTpullteam
01-28-2005 19:31:06
 Re: Tires???? in reply to DTpullteam, 01-27-2005 16:27:19
Thanks for your views.Pulling two tractors and this is first year for cut tires and I'm going nuts! 3500 to 6500 classes.
CrazyAllis
01-27-2005 18:39:50
My favorites are Firestone 151's with a 3/4" cut or super all tractions and a 1/2" double cut.Depends on what weight as far as ply rating,we pull light so we use 6 plys cause you don't want to much side wall flex because you loose drawbar hieght.Then you watch some of the divI&II tractors wrinkle the tires to the point the rim almost touches the ground and get along fine!Remember if all else fails; Take a guess and hope for the best!
