High Volume Petcocks
jdgpuller
01-26-2005 15:03:37
hey,
I"m looking for a set of high volume petcocks to put on our pulling John Deere G. I was wondering where you would buy these.
Thanks
ToddF
01-27-2005 07:19:06
 Re: High Volume Petcocks in reply to jdgpuller, 01-26-2005 15:03:37
I ordered some brass drain cocks from McMaster-Carr for our puller. They are like $4.00 each. I bought the "T" handle type because I was concerned that gravity and vibration might open a lever handle type. I would now consider using the lever handle type because they are stiff enough that they wouldn't open and the "T" handles can be an SOB to open and close; not enough leverage to turn them, and after a few seconds of struggling with them they get too hot to touch without gloves and I end up using my Leatherman to grab hold and close them.
JerryBird
01-27-2005 05:42:01
I bought a couple sets from Triple G Service.They are a very compact ball valve (inch and1/4 when thread in),with a small "T" handle.I,m happy with them.Their toll free number is 1-888-720-0830.
Bob-Wyo
01-26-2005 18:25:43
gpuller better listen to Earl, same thing I have been running for years in my D's, and Earl also knows where the BEST chicken and noodles place is. LOL Bob
Earl S.
01-26-2005 17:50:48
Puller, I have used 1/4 pipe brass drain cocks for years on our 2 cyl pullers they work fine. The hole in them are 1/4 in. If your hand cranking you might want to turn at least the left hand down a little to make starting easier on stock comp. tractors.You should be able to find them at any good auto parts store that has a good brass assortment.The only thing the handle works opposite to the Deere cocks.Earl In Illinois
The Rodent
01-26-2005 16:53:26
Hey, jdgpuller I would not recommend using hardware store valvles. They probably couldn't stand the heat or pressure. Have to make your own some how, or find a place to buy them. BEST OF LUCK!!!
Drew
01-26-2005 16:05:04
Go to the hardware store and dig in the brass fittings and you should find a valve to suit you. A word of warning though; if you put too big of petcocks in it, it will be a B!@%h to start.
M Puller
01-26-2005 15:22:11
Have you tried drilling yours out
