What size tire for a John Deere A
padd
01-26-2005 05:06:12
I have a stock 48 creeper gear john deere A and I keep running out of traction with my 13.9's. I have found a set of worn firestones that are 15.5 x 38 and I am wondering if my tractor will be able to turn them. Also will a 15.5 rim be what I would want to mount them on.
Thanks
52 A Boy
01-27-2005 14:47:15
 Re: What size tire for a John Deere A in reply to padd, 01-26-2005 05:06:12
I have a 52 JD A bored .125 with high compression aluminum pistons, running 16.9X38"s on a 14 in. rim, i run from 7100-8100 pounds. On hard tracks it will pull down pretty good in 8100 but i still have broke loose before the engine gave up. Go with 16.9"s on a 14 in. rim
52 A Boy
toot
01-26-2005 05:56:47
The creeper gear A"s did not start til 1950. But, if you do have the creeper A 15.5 will not be a problem to turn over.
jugs
01-26-2005 05:43:57
if rules allow, go to a 16.9x38. You may have to drop a gear, but you will be moving A LOT faster!. If your tractor is a 48 it is not a creeper. Is it a high-low trans? I have mounted 16.9's on a 12" rim with good results.Otherwise a 14" rim is ideal. 15.5's...I wouldn't bother. Keep the 13's on. The 15.5's are a low profile tire. Are you under a spped limit or max tire size? All play a factor in what you can do. !4.9 would also be an excellent choice, more than a 15.5 if you can't run 16.9.
JDTH
01-26-2005 09:34:21
 Re: What size tire for a John Deere A in reply to jugs, 01-26-2005 05:43:57
We have a '47 A with a newer clutch and primary gear. Have used 15.5" tires for the last year, pulling 4500-6500# classes. In 4500-6000#, we pull third gear where speeds allow. 6500# requires second, loss of traction is a problem most of the time. Have just bought a pair of 16.9" x 38" tires for pulls that will allow.
apuller
01-28-2005 11:32:58
 Re: What size tire for a John Deere A in reply to JDTH, 01-26-2005 09:34:21
what have you got done to your motor to be able to pull in that high of a gear??
JDTH
01-27-2005 04:39:36
The stock block has been bored, P & W pistons, longer rods, cam, head work, intake and carb work, ignition. Stroked crank and roller rockers are being installed at this time. 16.9's will be a must, if not 18.4's.
Padd
01-26-2005 10:12:18
JDTH, what else have you done to your motor? Also are you not recomending the 15.5's or would you keep them. I am concerned that I may recieve some greif if I go to a 16.9 tire at some of the pulls around me. And to clarify it is a 48A but I have changed the pulley and reduction gear from a 51A. Thanks
big jugs
01-26-2005 17:26:06
 Re: What size tire for a John Deere A in reply to Padd, 01-26-2005 10:12:18
Justb changing the two gears on the pulley, first reduction doesn't make it as slow as the creeper gear.
JDTH
01-27-2005 04:34:30
 Re: What size tire for a John Deere A in reply to big jugs, 01-26-2005 17:26:06
The change of the clutch and primary gears slowed the mph down approx. 10 percent in each gear at the same rpm.
Drew
01-27-2005 15:31:20
 Re: What size tire for a John Deere A in reply to JDTH, 01-27-2005 04:34:30
Would you happen to know the tooth count on the gears you installed? Thanks
padd
01-28-2005 04:51:43
 Re: What size tire for a John Deere A in reply to Drew, 01-27-2005 15:31:20
No I did have it somewhere but I have thrown it away I guess. If you need any info on what is involved just reply back.
