Cams
Farmall guy
01-25-2005 17:06:52
Who do most of you use for custom cams. I dont have a clue who is good. Thanks
smoker
01-27-2005 00:16:18
 Re: Cams in reply to Farmall guy, 01-25-2005 17:06:52
barry cam lester prairie mn,has a wide selection of custom grinds,and they are cheap!!
Clarence Barenie
01-26-2005 15:24:31
From experience!
IF your running close to stock cubic inch i would not recommend a cam grind at all.
Several years ago, i had one done for a 281ci m, cam grinder did a great job, price was fair, turn around time was excellent, no complaints.
The only problem was it was to much lift for that size motor, lost alot of low end torque. I would ask (if your pulling a farmall) all four of the major engine builders on this board, what to use and what the cost is ! START also with the correct camshaft also their are different grinds for (ranges) of cubic inch !
redhpuller
01-26-2005 09:43:59
lemmons tractor service also is good.Roughly 225$ w/ a core for a mid range cam.I know for an H the mid range cam duration is 198.Supposed to be a 15-20% increase in power.# is 1-765-938-1808. ask for greg.
Kenny Chinsey
01-25-2005 17:40:21
Bullet Cams. Ask for Sonny. They do good work, quick turnaround time and not too expensive.
http://bulletcams.com/index.shtml
Hillbilly Hooker
01-25-2005 19:58:34
 Re: Cams in reply to Kenny Chinsey, 01-25-2005 17:40:21
I agree with Kenny, Sonny will do you a good job. Tell him what you want as far as RPMs etc. and he can fix you up. H.H.
