Reasonable stroke limit for IH C-264 block
R.H.
01-29-2002 19:34:51
I know the sky is the limit for a bottomless purse, but lets be realistic and practical. When M&W made stroker cranks, they where 5 3/4 and required block and cam grinding. If a stock crank is cut and stroked, whats the limit before block and cam grinding becomes excessive and reliability suffers? I'm guessing 6 to 6 1/4 with stock rods. One reputable engine builder I'm aware of can go the 6 3/8 or 6 1/2 with custom crank/rods and no cam grinding. But the dollars per cubic inch ratio is very high!
DRR
01-30-2002 09:20:21
 Re: Reasonable stroke limit for IH C-264 block in reply to R.H., 01-29-2002 19:34:51
The M W 5 3/4 crank does not require any grinding or modification.I have one I built.
ihcSuperM
01-29-2002 19:42:10
From what I've been told, 6-1/4 is probably your best bet if on a budget like me. You can use stock rods with a piston that has the rist pin location to accomodate the additional stroke. There is a minimal amount of grinding to block and camshaft. Check with Lemmons Tractor Service. They seem to have an excellent reputation when it comes to this stuff.
farmall flogger
01-30-2002 13:53:55
 Re: Re: Reasonable stroke limit for IH C-264 block in reply to ihcSuperM, 01-29-2002 19:42:10
Know one guy who's gone 6 1/2 with the standard M rod.
