450 block
Kenny Chinsey
01-25-2005 12:38:45
Does anybody know the part number for a 450 Farmall gas engine block (C-281)? Also, will a late model gasoline M crank, camshaft, oil pump etc. work in a 450 gasoline Farmall block? Trying to make a pulling engine with M parts in strong 450 block.
Thanks in advance.
Kenny Chinsey
01-25-2005 17:36:46
 Re: 450 block in reply to Kenny Chinsey, 01-25-2005 12:38:45
Thanks guys!!
Flogger
01-25-2005 14:07:06
Hey Kenny, about the only problem I remember is that an M distributor drive won't bolt up to a SM-450 front cover. The M front cover fits the SM-450 blocks just fine, so as long as you use the front cover and ignition from your M you'll be OK.
CASEPOWER
01-25-2005 13:17:52
356980 C-281 is the casting # I believe all the other parts will interchange. But, I am sure a Farmall man could tell you morw.
ChadS
01-25-2005 14:09:28
 Re: 450 block in reply to CASEPOWER, 01-25-2005 13:17:52
The difference is in the bearing inserts. SM-450 cranks have a larger diameter main, and rod journal, thus a thinner insert used. Just keep the bearings with the crank, M crank, M bearings, in the 450 block. ChadS
Flogger
01-25-2005 14:13:57
 Re: 450 block in reply to ChadS, 01-25-2005 14:09:28
I think the late production Ms had the big journal crank too.
CASEPOWER
01-25-2005 14:24:52
 Re: 450 block in reply to Flogger, 01-25-2005 14:13:57
I posted the serial # were it changed one time, but would have to look it up. I didn't think there was anything else much different besides the sleeves and pistons, but I didn't want to open mouth and insert my foot. It's easy to do here.
Flogger
01-25-2005 14:29:28
 Re: 450 block in reply to CASEPOWER, 01-25-2005 14:24:52
You did, it's somewhere after 200,000.
ChadS
01-26-2005 06:30:56
 Re: 450 block in reply to Flogger, 01-25-2005 14:29:28
Also a diiference in the weight of each crank. ChadS
