Pistons
Sleddog
01-24-2005 16:56:30
I am gathering parts to rewbuild a Farmall SH engine. I would like to hit 50 HP.Will a Farmall 350 sleeve fit a Farmall SH block? What is the difference in the pistons? How could the sleeve and piston be made to fit?
ChadS
01-24-2005 19:50:40
 Re: Pistons in reply to Sleddog, 01-24-2005 16:56:30
No, not without boring the block to match the 350 sleeve barrel diameter, then you have to cut the 350 sleeve flange down to match the H block, otherwise you will overbore the block deck to accomidate the larger flange size. You can remove the sleeves, and drop the 3-5/8 right in after you clean up the block bores. Super H over bore kits are 3-9/16, large pin pistons,, 350 pistons are 3-5/8 small pin pistons. I have pistons that will do what you are looking to do. 574-893-7437. ChadS
