looking for replacement turbo
new FS puller
01-23-2005 18:25:33
can anyone tell me a good replacement turbo for a 531 6030? something with a little more a$$ for pulling. how much would it cost and how much would it help.
buickanddeere
01-24-2005 06:46:21
 Re: looking for replacement turbo in reply to new FS puller, 01-23-2005 18:25:33
Link
ol George
01-23-2005 18:35:25
How much more are you wanting. I assume you are talking farm stock pulling. I am thinking something in a 3*4 or slightly larger would work with those cubes.
new 6030 puller
01-24-2005 10:36:52
 Re: looking for replacement turbo in reply to ol George, 01-23-2005 18:35:25
George,
it's farm stock pulling. Is that 3in and 4 out or vise versa? I would like to go bigger, but don't know how big I can go with stock manifolds. If you know brands and model numbers that would really be a good start. Thanks.
BLACK SMOKE
01-24-2005 19:31:42
 Re: looking for replacement turbo in reply to new 6030 puller, 01-24-2005 10:36:52
with the cubes you have you should be able to run a th-08 without any trouble,you will need a adapter plate though.
you also have the cubes to turn a T-18-95,but i think your head gasket may go south in a hurry with that one.
new 6030 puller
01-24-2005 21:51:45
 Re: looking for replacement turbo in reply to BLACK SMOKE, 01-24-2005 19:31:42
That's just the kindof info Im looking for.
Who makes a th-08? garret? holset? St. joe. Does everybody make a th-08? Thanks alot for the info.
ol George
01-25-2005 17:13:59
 Re: looking for replacement turbo in reply to new 6030 puller, 01-24-2005 21:51:45
I still think the s-4 switzer or a to8 air research will work. Just trying to figure the correct housings to make it work best.
BLACK SMOKE
01-25-2005 17:34:07
 Re: looking for replacement turbo in reply to ol George, 01-25-2005 17:13:59
i was thinking a t-18-95 with around a 132 ex. on it would work,it really depends how much fuel you have and how much boost you want.
if you turn the engine @ 4000 rpm you would want more like a 118 ex.
columbus is pretty good a figureing the turbo combo,just don't buy injectors from them,we have had nothing but trouble with theirs.
we now get them form midwest diesel in ft dodge ia.
a th-o8 is a aireaserch/garrett,i'm not sure what housings to run on this,but it should run around 50-65 psi,the 18 should run 60-80 psi.
the t-18 will also cost less,th-08 is the old bottom charger on the supers.
new 6030 puller
01-25-2005 18:52:36
 Re: looking for replacement turbo in reply to BLACK SMOKE, 01-25-2005 17:34:07
Thanks alot you guys. your experience is very appreciated. It the stock bosch pump and I assume the injectors are stock. Any advice here? What kind of rigs do you guys run?
BLACK SMOKE
01-26-2005 16:01:28
 Re: looking for replacement turbo in reply to new 6030 puller, 01-25-2005 18:52:36
call midwest diesel in fT dodge ia a call.
he will help you with any pump/turbo combo you can think of.
i pull a 1586? in the 7000 & 8500 lbs open classes at the local fairs,436 ci with T-18-74 and a P-Pump,turns about 6000 rpm.
new 6030 puller
01-26-2005 18:13:29
 Re: looking for replacement turbo in reply to BLACK SMOKE, 01-26-2005 16:01:28
Thanks for the advice and I hope you kick a little A$$ out there this year!
