strokkkkking a zzzzz moline
roland withersp
01-22-2005 15:23:23
1 " stroke what piston help and will it work?
Don in NY
01-23-2005 05:06:45
 Re: strokkkkking a zzzzz moline in reply to roland witherspoon ohio r, 01-22-2005 15:23:23
witherspoon,
I did a 1" strock on a 206 z motor, came out nice alot more power at a lower rpm range. Of coruse the higher rpm gives you still more power if you biuld you motor for higher rpm use.
I had to have the pistons made I used aires hope this helps.Don
Z- Puller
01-23-2005 13:41:06
 Re: strokkkkking a zzzzz moline in reply to Don in NY, 01-23-2005 05:06:45
Don, do you have part number of the aries pistons.
