5 3/4 Pistons for john Deere A around 8 inches lo
Living to pull
01-17-2005 16:47:44
I need two 5 3/4 inch pistons prefably cattapillar pistons
Earl S.
01-17-2005 16:55:41
 Re: 5 3/4 Pistons for john Deere A around 8 inche in reply to Living to pull, 01-17-2005 16:47:44
Do you want new or good used ???Earl
Living to pull
01-17-2005 19:59:28
 Re: 5 3/4 Pistons for john Deere A around 8 inche in reply to Earl S., 01-17-2005 16:55:41
I doesn't matter as long as they are good. The new once would probably be very very expensive so used would probably be better. Just depends on price
JDGnut
01-18-2005 15:05:47
 Re: 5 3/4 Pistons for john Deere A around 8 inche in reply to Living to pull , 01-17-2005 19:59:28
We have used the Pratt & Whitney pistons.. 5 3/4 bore... the are short and light.. new they were cheaper than a set of stock pistons... JDGnut
Earl S.
01-18-2005 08:36:17
Living , This is the piston I used in the past. 2703 PN. Sealed Power . Its not a good match unless you are stroking or lengthing your rods. Earl In Illinois
