schwitzer S2B turbo
TURNEY
01-17-2005 14:00:34
I have a schwitzer s2b turbo would you be able to get it to work on a farmall 282 diesel I have a turbo manifold to fit the 282d. I guess my question is will it be to big or small for that motor .
ejr
01-18-2005 17:15:31
 Re: schwitzer S2B turbo in reply to TURNEY, 01-17-2005 14:00:34
Don't know what size that would be.Your manifold is it a M&W or the one used on the TD9cat?I have 2 560s with turbos.I use Airresearch TO4s with small exhaust wheels and turbine houseings to turn them hard enough to make boost.If I get them over 25lbs of boost can put antifeeze out the stock headgaskett.
ejr
01-18-2005 12:08:47
Whats the turbo off of?
TURNEY
01-18-2005 15:56:08
 Re: schwitzer S2B turbo in reply to ejr, 01-18-2005 12:08:47
93 Mack CS 200 they took it off when they rebuild the moter but it was working fine.
ol George
01-17-2005 17:22:31
It will definitely make it come alive. How many r's are you planning to run.
TURNEY
01-17-2005 19:24:24
 Re: schwitzer S2B turbo in reply to ol George, 01-17-2005 17:22:31
I have had this idea to do this for a while and I am slowly geting the parts. I wont to do it to a 656 or a 706. I wont to use around the farm so not to radical need to be dependable. It will be down the road rebiulding a 560 gas and I am puting a 301 in it . just wondering if the turbo would work
