governor springs from Chad S.
red express
01-16-2005 12:32:40
how much are the springs for 10 percent overide and we they help on stock or stroker motors
ChadS
01-18-2005 09:11:23
 Re: governor springs from Chad S. in reply to red express, 01-16-2005 12:32:40
On sale this week! It helps your governor response time. More sensitive, more rpm, faster throttle responce for all types of engines running a stock governor that needs to get some snap in the throttle response. Also, in the low lugging rpms, the old weak stock spring will actually be overpowered by the governor weights, thus shutting the carb down faster as the engine rpms begins to drop. The new spring will keep the tension on the weights, and keep the rpms longer under these condidtions. Mite make the difference in an inch or ten feet. Thanks, give me a call if you wish, 574-893-7437. ChadS
