stroking a 66 oliver
FJB
01-14-2005 18:21:58
Does anyone know how much you can stroke a 66 oliver engine? And what can be done to get the most power out of a oliver 66?
C Shaffer
01-16-2005 04:29:47
 Re: stroking a 66 oliver in reply to FJB, 01-14-2005 18:21:58
I have a 2" stroke in my 66. and could have gone another .125. But you need to flat machine the cam. I have a stroker 66 crank, rods, sleeves and piston set that would bring you up to around 65 hp if I do your, cam, head, manifold and carb. I build Oliver motors, the kit above I can assembel for you and all you need to do is swap motors. That will put you to 207 cubes and run 93 or 94 octain. Give me a call or email me 585-335-9274, Charlie
sos puller 2
01-15-2005 19:11:25
you can do the same to them as you can a 77 but you are short 2 cy my 66 does 55 hp but i need a little more stroke yet
