820 rear hubs
richard
01-27-2002 10:35:46
anybody out there ever weighed one to see what exact weight was.would like to know. 820 puller
G Taylor
01-27-2002 15:33:18
 Re: 820 rear hubs in reply to richard, 01-27-2002 10:35:46
Albert at [email protected] has cut down cast hubs for the R,80,820 & 830 drilled to take pressed steel centers/rims.
JDGnutt
01-29-2002 10:30:32
 Re: Re: 820 rear hubs in reply to G Taylor , 01-27-2002 15:33:18
This isn't going to answer you question on how much the hubs weigh.. but another way to lighten the wheels/hubs is to find a 9 bolt dual hub.. you will have to do some minor modification to the axle, but they will fit.. and will easily go back to stock.. U just just have to find the correct size of wedges for the hubs to fix the axle. Most of the JD hubs are the same size,(the 9 bolt hubs) but the wedges are different to change between axles sizes. Good luck
JDGnut
